DGNIMPORT command
Imports MicroStation DGN files (*.dgn) into the current drawing.
Opens the Import file dialog box to select a .dgn file to import into the current drawing.
Note: Run the DGNIMPORTOPTIONS command to open the Settings dialog box with the DGNIMPORT category expanded. All options affecting the import of .dgn files can be modified here.
