DIMCENTER command
Creates a center mark.
Icon:
Create a center mark at the center of a circle, arc or polyarc. See the CENTERMARK command to create associative center marks.
Method
There is one method to begin creating a center mark.
  • Select arc or circle to dimension
Options within the command
Creates a center dimension by selecting an arc, polyline arc segment, or circle.
Note: The DIMCEN system variable controls the length and appearance of the center mark lines.
