DIMMARKOVERRIDES command
Adds or removes underline to dimensions with overridden dimtext.
Adds or removes underline to dimensions with overridden dimtext by making database modifications.
- Select dimensions
- Select dimensions with overridden dimension text. When all desired dimensions are selected, press Enter.
Note: To mark dimensions with overridden dimtext without database
modification, set the DIMMARKTYPE system variable value to 1 or 2.
Options within the command
Once all desired entities are selected, two options are available:
- Mark
- Underlines the overridden text for the selected dimensions.
- Unmark
- Removes the overridden text underline for the selected dimensions.
