DMPARALLEL3D command
Applies a parallel constraint between subentities of 3D entities.
Icon:
Method
Select two faces of a solid or two faces of different solids or surfaces or a face and an edge of two different solids between which the parallel constraint will be applied. Press the TAB key to select obscured geometry.Options within the command
- WOrld
- Allows you to select the WCS subentity as an argument.
- BLock
- Allows you to choose, as an argument, the subentity of the coordinate system of the block.
