DMPATH3D command
Allows a point to move along a curve by specifying the curve's parameters.
Icon:
Method
Select any curve entity (polyline, 3D polyline, spline or helix) as the path and a point/vertex from a 3D solid and specify the value of the curve parameter. Press the TAB key to select obscured geometry.
Options within the command
- WOrld
- Allows you to select the WCS subentity as an argument.
- BLock
- Allows you to choose, as an argument, the subentity of the coordinate system of the block.
- Geometry-driven
- Accepts the current value and creates a geometry-driven constraint.
