DMPERPENDICULAR3D command
Applies a perpendicular constraint between two subentities of two 3D entities.
Icon:
Applies a perpendicular constraint between faces or edges of a solid, or of different solids or surfaces.
Select the two subentities of the 3D entities between which the perpendicular constraint will be applied. Press the TAB key to select obscured geometry.
Options within the command
- WOrld
- Allows you to select the WCS subentity as an argument.
- BLock
- Allows you to choose, as an argument, the subentity of the coordinate system of the block.
