DMSIMPLIFYALL command
Simplifies the geometry in solids, within drawings inserted as external references.
Removes unnecessary edges and vertices, merges seam edges, and replaces the geometry of faces and edges by analytic surfaces and curves, if possible within the user-specified tolerance.
Note: It is recommended to always run this command on imported drawings with inserted external references.
Options within the command
- Entire model
- Simplifies the entire model.
- SEttings
- Allows you to access the command settings.
- Geometry
- Define the geometrical settings.
- ON
- Switches topological/geometrical simplification on.
- OFF
- Switches topological/geometrical simplification off.
- Topology
- Defines the Topology settings.
- Auto
- Simplifies the detected geometry or topology.
