DWGHEALTH command
Combines the functionality of multiple stand-alone BricsCAD commands that help to improve overall drawing size and accuracy.
Icon:
Combines the power of multiple commands (PURGE, AUDIT, FINDOUTLIERS, SIMPLIFY, OVERKILL, BLOCKIFY, OPTIMIZE, ARRAYDETECT) in one location. Reduces drawing size, removes unused styles, entities and layers and improves drawing quality.
You can run the DWGHEALTH command in the Interactive mode.
When you run the command for the first time, a tutorial dialog opens, explaining the DWGHEALTH command in two steps.
The DWGHEALTH command opens the Drawing Health Command Context panel:
- Create new
- Select a routine
- Drop-down list
- Save as
- Edit
- List of the tasks included in the routine
- Interactive mode
- Start
Create new
Opens the Create Routine dialog box that allows you to add a new routine. See the related article Create Routine dialog box.
Select a routine
Allows you to select a routine from the drop-down list.
Drop-down list
Lists all available routines, predefined and custom.
The predefined routines are:
- Fix errors
- Analyze and repair 2D and 3D entities in your drawing.
- Reduce drawing size
- Reduce drawing size (where applicable) by removing unused objects, duplicate overlapping geometry, and block definitions with identical contents. Properties to be included or filtered can be selected under each task.
Click the Manage routines... button to open the Manage Routines dialog box. See the related article Manage Routines dialog box.
Save as
Opens the Save Routine dialog box to save the custom routine with the desired name.
Edit
Opens the Edit Routine dialog box where you can edit the selected routine. See the related article Edit Routine dialog box.
Lists all tasks that will run with the selected routine.
Interactive mode
Switches to manual checks and fine-tuning. For each routine task, a panel will open containing the same options as the corresponding commands, where you can fine-tune the cleanup of the drawing.
Start
Performs the routine.
If the Interactive mode button is active, a panel opens for each routine task. Choose your settings and press the Next button to open the next task panel.
After the last task, it opens the Report on the drawing's cleanup, which displays all items detected and cleaned.
