EXPIMAGES command
Opens the Drawing Explorer dialog box with Images selected.
Icon:
Supports the following formats:
BMP: Windows bitmap
ECW: Enhanced Compressed Wavelet format
GIF: CompuServe graphic image format
JPG, JPEG, and JPEG2000 (JP2, j2k): Joint Photographic Experts Group (common among digital cameras)
MTI: Multi-resolution Tiled Image (Bricsys raster format for large images)
PCX: PC Paintbrush
PNG: Portable network graphics
SID: MrSID is an acronym for Multi-resolution Seamless Image Database
TGA: Targa
TIF, TIFF: Tagged Image File Format
Context Menu Options
- New
- Attaches raster image files to the drawing. dismisses the Drawing Explorer dialog box, and the starts the IMAGEATTACH command. See IMAGEATTACH command.
- Delete
- Removes the image from the drawing. You may need to use the REGEN command to update the screen.
- Insert
- Inserts more images in the drawing, like the New button. Displays the Attach Raster Image dialog box. See IMAGEATTACH command.
- Run extended search for missing attachments
- Runs an extended search for missing attachments.
- Clear cash
- Clears the folder where temporary image cache files are stored.
- Relative path
- Shows the Saved Path as a relative path.
- Absolute path
- Shows the Saved Path as an absolute path of the image located in the drawing folder.
- Filename as a path
- Replaces the saved path with the file name.
Options within the columns
- Name
- Specifies the name of the image. This usually is the image's file name.
- Load
Toggles whether the image is displayed in the drawing:
On: displays the image in the drawing
Off: displays only the image's frame, which is turned off by the IMAGEFRAME command
- Size in Pixels
- Reports the size of the image in pixels, horizontally and vertically.
- References
- Reports the number of times the image occurs in the drawing.
- Saved Path
- Reports the path to the image file when first loaded. When the path cannot be found, click the Browse button which will display the Choose a File dialog box and locate the missing image file.
- Found Path
- Reports the current path to the image file. This path should match the Saved Path in most cases.
