EXPORTTOBRICSCAD command
Converts AEC entities into native entities.
Icon:
Creates a new version of a drawing file with all AEC entities converted to blocks containing native entities.
Note: The EXPORTTOBRICSCAD and EXPORTTOAUTOCAD commands are identical.
Method
Define the file format, whether to bind Xrefs, the bind type, the file name prefix, and the file name suffix, or keep the default settings.
If you enter a file name (not accepting the default one) in the command line (FILEDIA=0), the output file will be created in the same folder as the original drawing, not the current working folder.
Options within the command
- Format
- Sets the file format of the new file. The default value is 2018.
- Bind
- Decide whether to bind the Xref files to the new drawing or not. The default value is Yes.
- bind Type
- Defines the behavior of Xref-dependent entities when the Bind option is set to Yes. The default value is Insert.
- Prefix
- Specifies the new file name prefix.
- Suffix
- Specifies the new file name suffix.
