account
translation
Bricsys Help Center
EXTRIM command (Express Tools)
Trims entities that cross a cutting edge.
Method
Select the cutting edge entity, then click on the side you want to erase the entities from.
Note: The cutting edge entities accepted are: 3D Face, Polyline, Line, Circle, Arc, Ellipse, Image, Text or Attribute Definition.
Related commands
  • BTRIM command (Express Tools)
  • EXTEND command
  • TRIM command
Related information
  • Express tools command overview
© 2026 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
