-FBXEXPORT command
Exports 3D entities in the current drawing to FBX format.
Method
Specify whether you want to select entities for export or export all visible entities. Then you are prompted to specify the entity types to export, the texture export method, and the path and filename for the FBX export file.
Note: If you want to export 2D entities, you must first give them a thickness.
Options within the command
Selected
Allows you to select the entities to be exported.
Visible
Exports all visible entities.
Note: This option excludes the entities on frozen or off layers, and those that are not visible in the current viewport.
Settings
Prompts you to choose whether to export entities, lights, cameras, and materials.
All
Exports all entity types.
Embedded
Includes the texture files into the FBX file.
Reference to file
Adds a reference link in the FBX file to the location of the texture files.
Copy of file
Copies the texture files to the destination folder, separately from the FBX file.
Note: Texture files are not included in the FBX files when they are very large or when a common set of texture files are used by rendering and animation projects.
Specify path and filename for FBX export file
Allows you to specify the path and filename for the FBX export file, or press the Enter key to accept the provided path.
Note: Type ~ to display the FBX export dialog box, which allows you save the FBX file.
