FBXEXPORT command
Exports 3D entities in the current drawing to FBX format.
Method
There are two methods to export to FBX format:
  • Export all visible entities.
  • Export only the selected entities.
Note: If you want to export 2D entities, you must first give them a thickness.
Options within the command
Selected
Allows you to select the entities to be exported.
Visible
Exports all visible entities.
Note: This option excludes the entities on frozen or off layers, and those that are not visible in the current viewport.
Select
Prompts to select among entities, lights, cameras and materials.
All
Exports all entity types.
Embedded
Includes the texture files into the FBX file.
Reference to file
Adds a reference link in the FBX file to the location of the texture files.
Copy to file
Copies the texture files to the destination folder, separately from the FBX file.
Note: Texture files are not included in the FBX files when they are very large or when a common set of texture files are used by rendering and animation projects.
Enter path to export fbx file:
Specifies the path to the folder in which to place the FBX file, or press Enter key to accept the path provided.
Note: Type ~ to display the FBX export: dialog box, which allows you save the FBX file.
