-FBXIMPORT command
Imports 3D entities from a FBX file into the current drawing via Command line.
Method
Specify the path of the FBX file to import via the Command line and choose the import settings.
Options within the command
- Settings
- Allows you to import or skip importing entities, lights, cameras and materials from the FBX file.
- Yes
- Imports the prompted element.
- No
- Skips importing the prompted element.
- All
- Imports all elements from the FBX file to the current drawing.
