HEALTHADVISOR system variable
Health advisor
Run drawing health in the background when opening drawings. A drawing will not be scanned again if it hasn't been changed since the last check.
Modify the routine by running the command HEALTHADVISORROUTINE.
Turn on TRAYNOTIFY and TRAYICONS to get notified when actionable results are found.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Do not run background advisor process
On (1): Run background advisor process
