-FLATSHOT command
Creates a flattened, hidden line representation of a 3D model via Command line.
Options within the command
- Insert new block
- Inserts a new block in the current drawing.
- Insertion point for block
- Specifies the insertion point of the block in the drawing.
- Corner
- Defines the X, Y, and Z scales at the same time, using the insertion point and the selected other corner for scale.
- scale X Y Z
- Specifies the X, Y, and Z scale factors of the Xref in the X, Y, and Z directions.
- Scale
- Specifies the size of the block.
- X scale
- Specifies the X scale factor of the block in the X direction.
- Y scale
- Specifies the Y scale factor of the block in the Y direction.
- Z scale
- Specifies the Z scale factor of the block in the Z direction.
- Rotate
- Specifies the rotation angle.
- Replace existing block
- Replaces a block that is already inserted in the drawing.
- Export to file
- Allows you to specify the full path and save the flatshot block as a DWG file via Command line.
- Advanced options
- Allows you to set the properties for the block you want to insert or replace.
- Visible line properties
- Sets the linetype and color for the visible lines.
- Hidden line properties
- Toggles the display of hidden lines and sets their properties.
- hidden line Resolution
- Specifies the smallest distance used for Hidden Line Removal calculation.Note: The value is saved in the ACISHLRRESOLUTION system variable. Negative value is Auto-calibration based on the size of the model (recommended). For very small entities the value can be set to 0.001 or smaller.
- Tangential edges
- Toggles the display of tangential edges.
- entity Layer
- Toggles whether the layers of entities in the block are maintained or not.
