GCVERTICAL command
Creates a vertical geometric constraint on 2D entities.
Icon:
Creates a vertical constraint to ensure a linear entity or pair of points remains parallel to the y-axis.
Method
This command has 2 methods to begin creating a vertical constraint.
- Select an entity
- 2 Points
Options within the command
- Select an entity
- Creates a vertical constraint by selecting a linear entity to make parallel to the y-axis.
- 2Points
- Creates a vertical constraint by specifying two points.
- Select first point
- Allows you to specify the first point to make parallel to the y-axis.
- Select second point
- Allows you to specify the second point to make horizontal to the y-axis.
The first point maintains its position while the second point moves to become vertical with the first point.
