GEOMAP command
Sets the visibility of online maps.
Displays a map from an online map service within the current drawing.
Important:
  • Bing Maps
    Bing Maps are deprecated and can no longer be used in BricsCAD. Bing Maps can be replaced without an API key (see the GEOMAPKEY command article) as follows:
    • bing Aerial is converted to esri Imagery.
    • bing Road is converted to open street Map.
    • bing Hybrid is converted to esri Hybrid.
  • Esri Maps
    The esri Imagery, esri Streets, esri Light, esri Dark, and esri Hybrid maps are available only when an API key is assigned (see the GEOMAPKEY command article).
  • OpenStreetMaps
    It does not require an API key and is free to use.
Note:
  • Make sure the geographical location and coordinate system are set using the GEOGRAPHICLOCATION command.
  • The copyright and watermark are added in the lower right corner of the drawing area. The application displays a message while tiles are downloading.
Options within the command
open street Map
The map is displayed in the open street Map map style.
Note: The source of the map can be changed through the GEOMAPOSMMODE system variable.
esri Imagery
The map is displayed in the Imagery map style.
esri Streets
The map is displayed in the Streets map style.
esri Light
The map is displayed in the Light map style.
esri Dark
The map is displayed in the Dark map style.
esri Hybrid
The map is displayed in the Hybrid map style, combining Imagery map style with labels.
Note: The source of the labels can be changed through the GEOMAPHYBRIDMODE system variable.
Off
Hides the geographical map.
