GETSEL command (Express Tools)
Creates a selection set of entities based on entity type and layer filters.
Icon:
Method
Select an entity on the source layer, then select an entity of the type you want.
For example, if you select at the first prompt an entity on NewLayer1 and at the second prompt a circle, the GETSEL command collects all circle entities on layer NewLayer1.
Note:
- The entities are placed in the current selection set.
- These entities can be selected using the SELECT command and entering P.
