GISCONVERT command
Converts Object Data in the current drawing from Autodesk Civil 3D to BricsCAD GIS data.
Converts Object Data (lines, polylines, points, or blocks) and Mpolygons in the current drawing from Autodesk Map 3D or Civil 3D to BricsCAD® GIS data.
The BricsCAD® GIS data is displayed in the Properties panel and in the GIS Attribute table dialog box.
A GIS Layer is created in the GIS tab from the Civil Explorer panel.
