Civil Explorer panel
Icon:
Civil Explorer is the main panel to manage and access Civil entities. Entities are arranged in a tree view and grouped by entity type.
Through this panel, you can access settings and properties of Civil entities and allows you to edit existing and add new entities and their components.
The panel is divided into two parts. The upper part with list of entities in a tree view, and the bottom part with additional properties, depending on the selection in the tree view.
The Civil Explorer panel is the core panel for Civil design. In the Civil Workspace, click the Civil Explorer icon in the Ribbon under the Home tab to toggle the panel on/off.
Note: Instead of individual Civil points, only point groups are listed on the Civil Explorer. Grading elements are listed in the tree-view, but it is not possible to edit their properties via Civil Explorer.
The Civil Explorer panel contains three tabs: Civil, GIS and Settings.
Civil Tab
The Civil tab enables you to manage and access Civil entities in the current drawing.
  1. Pick a Civil object
  2. Civil object types
  3. Selected Civil object
  4. Info
  5. Definitions
  6. Statistics
  7. Visual Styles
Pick a Civil object
Pick a Civil object in the drawing.
Civil object types
Civil objects are arranged in a tree view. At the top of the tree structure, all types of objects are listed. At the lower level, under each type of objects, the objects that already exist in the drawing are collected.
Right-click the Civil object type to open a context menu that contain the Create option, which launches specific commands to create a selected Civil object.
The right-click menu also contains a Hide option that can toggle the visibility for each type of Civil object.
Highlights the selected Civil object in a tree-view.
Right-click the entity to open a context menu that contains entity-specific Edit options, as well as options common to all entities, such as Zoom to, Select, Delete, and Hide.
The available edit options depend on the entity type:
Points
Existing points are not listed on the Civil tab in the Civil Explorer. You can create new Civil Points by right-clicking the Points and selecting Create from the context menu.
Point Groups
Select the Create option from the context menu to open the Point Group dialog box.
The context menu for a defined Point Groups contains the Civil Point Editor, Edit point group, Zoom to, Select, Pan to, Delete, and Hide options.
Note: Double-click a Point Groups node to open the Civil Point Editor dialog box.
Note: Edit Point Editor opens the Point Group dialog box.
TIN Surfaces
Using the Civil Explorer, you can Edit existing and Add new elements to existing TIN Surfaces.
Note: All the options under Add and Edit in the context menu are also available in the TINEDIT command.
In addition to these options, you can choose between the manual and Automatic Rebuild. You can also Create snapshot.
Use the Settings tab to edit Surface label styles.
Volume Surfaces
Zoom to, Select, Delete, and Hide options are available for Volume Surfaces.
Gradings
In addition to the common options, there are Split and Merge options available for Gradings.
Note: This Edit options are also available in the GRADINGEDIT command.
Alignments
The Alignments entity type collects existing Horizontal Alignments and associated Vertical Alignments, 3D Alignment and Vertical Alignment Views.
Right-click the Horizontal Alignment provides all the Edit options available in the ALIGNMENTEDIT command.
While for Vertical Alignments, Vertical Alignment views and 3D Alignments, the Zoom to, Select, Delete, and Hide options are available.
Corridors
Right-click the existing Corridor provides all the Edit options available in the CORRIDOREDIT command. Besides Edit options, also the Zoom to, Select, Delete, and Hide options are available.
Corridor Templates
You can choose between Add template element, Zoom to, Select, Delete, and Hide options.
Note: The Add template element option is also available in the CORRIDORTEMPLATE command.
Corridor Template Elements
Right-click the Horizontal Alignment provides all the edit options available in the CORRIDORTEMPLATEELEMENTEDIT command. Besides Edit options, also the common options, such as Zoom to, Select, Delete, and Hide are available.
Info
Displays information about the selected Civil object (Name and Description). Both can be edited.
Definitions
It shows the components (source data) from which the TIN surface was built, the editing operations used, and the chronological order in which definitions were added. You can switch view by selecting the By component or the By step tab.
8. By step
9. By Component
10. List of all definitions/components used to create the TIN Surface
By step
Displays all the steps to create the TIN surface.
The surface build process for a TIN surface is incremental. When you add data to a surface or edit the surface, the surface is updated. When data is removed, the surface is rebuilt. The step list supports the incremental build process and sequentially shows all operations performed on the surface in its current state. It is possible to change the order via the context menu or delete a step by right-clicking on a step. Step ID indicates in which step each component was added to TIN Surface. Step ID is also displayed in the Component view to make it easier to see the connection between the components and the step list.
By Component
Displays the definitions by components.
In the By component tab you can find Boundaries, Breaklines, Drawing entities, Edits, Point File, Civil Point Groups and Point Clouds. This tab comprises the data components that you can add to a TIN Surface.
Lists all TIN surface definitions. The context menu offers the possibility to change the order of definitions, to Delete or Disable them. Additionally, for most TIN Surface definitions, there are the options Select and Zoom to, which makes finding them in the drawing very easy. Double click a definition or press the Edit option from the context menu to open the Surface: Surface name, Definition step ID dialog box, which displays all details for the selected definition. You can edit the definition parameters.
Statistics
The Statistics tab displays the statistics for the selected TIN surface (number of points and triangles, minimum and maximum elevation, 2D and 3D area).
  1. Statistics tab
  2. Statistics data
Visual styles
The Visual styles tab allows you to set the visual styles for the TIN surface:
  • general visual style – choose which components of the TIN surface to display (Border, Points, Triangles).
  • visual style for contours.
  • visual style for the elevation analysis.
  • visual style for the slope analysis.
General
Enables/disables the display of certain TIN surface components.
Border
Toggles the display of the Boundary line of the TIN surface.
Points
Toggles the display of the Points of the TIN surface.
Triangles
Toggles the display of the Triangles of the TIN surface.
Contours
Specifies parameters for displaying contours on a TIN surface.
Enable Contours
Toggles the display of the Contours of the TIN surface. The visual style of the contours can be adjusted.
Major contours interval
Allows you to enter the interval for the major contours.
Major contours color
Allows you to enter the color for the major contours.
Minor contours color
Allows you to enter the color for the minor contours.
Elevations
Specifies parameters for creating TIN Elevations Analysis.
Enable Elevations
Toggles the display of the Elevations of the TIN surface. The visual style of the elevations can be adjusted.
Create ranges by
Allows you to choose between the methods of creating Elevation Analysis:
  • Number of ranges
  • Range interval
  • Range interval with datum
Color scheme
Allows you to select the color scheme for the Elevation Analysis.
Choose between the available options:
  • Spectrum
  • Earth
  • Hydro
  • Gray
  • Reds
  • Greens
  • Blues
Above datum color scheme
Allows you to select the Above datum color scheme.
Below datum color scheme
Select the Below datum color scheme.
DisplayAs
Select the TIN Surface elements used to create the Elevation Analysis.
  • Triangles
  • Contours
  • Points
  • 2D Triangles
  • 3D Contours
Range interval
Specifies the Range interval for the Elevation Analysis.
Number of ranges
Specifies the number of ranges for the Elevation Analysis.
Datum
Specifies the datum elevation.
Slopes
Specifies parameters for creating TIN Slopes Analysis.
Enable Slopes
Toggles the display of the Elevations of the TIN surface. The visual style of the slopes can be adjusted.
Color Scheme
Allows you to select the color scheme for the Slopes Analysis.
  • Spectrum
  • Earth
  • Hydro
  • Gray
  • Reds
  • Greens
DisplayAs
Select the TIN Surface elements used to create the Slopes Analysis.
  • Triangles
  • 2D Triangles
GIS Tab
GIS Tab contains a list of all the GIS layers in the drawing and helps you manage their visibility.
If there is no GIS layer in the drawing, there are three options on the GIS tab:
  • Import GIS Layer
  • Create GIS Layer
  • Convert from Object Data
  1. Import GIS layers
  2. Create new GIS layer
  3. Convert from Object Data
  2. Create group and Create GIS layer
  4. GIS tree view
Import GIS layers
Allows you to import the selected Shape files. After the Shape files are selected, the GIS import dialog box opens. Check the GISIMPORT command for the detailed description of GIS Import dialog box.
Allows you to create a New GIS Layer. The Create New GIS Layer dialog opens when the command is launched:
Name
Allows you to enter the new Layer name.
Geometry type
Allows you choose between the following geometry types:
  • Point
  • Line
  • Polygon
Add Field
Adds a new field.
When clicking the Add field button, a new field is added to Fields list, with the default name NewField and default type String. You can edit the Name and Type fields.
The following field Types are available:
  • String
  • Real
  • Integer
Click the trash icon in the table to delete fields.
When you first open the table of a newly created GIS Layer, the table is empty. It contains columns with names only.
Converts Object Data in the current drawing from Autodesk Map3D or Civil 3D to BricsCAD GIS data.
GIS tree view
Lists all GIS layers and groups.
Note: You can rearrange groups and GIS layers by using drag and drop.
The following context menu opens when you right-click a GIS Layer:
Open attribute table...
Opens the GIS Attributes Table dialog box.
Edit GIS layer
Opens Edit GIS Layer dialog box.
Select
Selects the GIS Layer.
Zoom to
Zooms to the GIS Layer.
Add GIS features
Adds entities to a GIS Layer. A command prompt for selecting linear entities in the drawing is shown. The GIS Attributes Table dialog box opens where the new GIS features are added at the end of the table. The table is scrolled to that location.
Export GIS layer
Exports the GIS layer.
Remove GIS layer
Removes the GIS layer.
The following context menu opens when you right-click a Group:
Rename group
Renames the group.
Add sub-group
Adds a sub-group.
Remove group
Removes the group.
Settings Tab
The Settings tab manages the civil entity styles and formats.
  1. General
  2. Civil Points
  3. Surfaces
General
Defines the general symbol styles for civil entities.
Symbol styles
Lists predefined and custom-created symbol styles. You can Create, Edit, Copy, or Delete a symbol style. Click the corresponding option from the context menu to open the Symbol Style dialog box.
Civil Points
Defines civil points file formats and label styles for civil points.
Point File Formats
Lists predefined and custom-created point file formats. The list can be managed by double-clicking or pressing the Edit option from the context menu which opens the Manage Point File Formats dialog box.
Predefined point file formats:
  • NameENZ (comma delimited)
  • NameENZ (semicolon delimited)
  • NameENZ (space delimited)
  • NameENZD (comma delimited)
  • NameENZD (semicolon delimited)
  • NameENZD (space delimited)
  • NameNEZ (comma delimited)
  • NameNEZ (semicolon delimited)
  • NameNEZ (space delimited)
  • NameNEZD (comma delimited)
  • NameNEZD (semicolon delimited)
  • NameNEZD (space delimited)
  • PENZ (comma delimited)
  • PENZ (semicolon delimited)
  • PENZ (space delimited)
  • PENZD (comma delimited)
  • PENZD (semicolon delimited)
  • PENZD (space delimited)
  • PNEZ (comma delimited)
  • PNEZ (semicolon delimited)
  • PNEZ (space delimited)
  • PNEZD (comma delimited)
  • PNEZD (semicolon delimited)
  • PNEZD (space delimited)
where:
  • P is Point Number
  • E is Easting
  • N is Northing
  • Z is Elevation
  • D is Raw Description
  • Name is for points that contain alphanumeric values for the point number. Also, the point name supports alphanumeric values.
Label Styles
Lists the available label styles for Civil Points. The context menu allows you to Create, Edit, Copy, or Delete a label style. Create, Edit and Copy options open the Label Style Editor dialog box which allows you to define a new label style.
Surfaces
Defines surface file formats and label styles for Contour, Slope and Spot elevation.
Surface File Formats
Lists predefined and custom-created point label style. The list can be managed by double-clicking or pressing the Edit option from the context menu that opens the Manage Point File Formats dialog box.
Label styles
Lists predefined and custom-created styles for Contour, Slope and Spot elevation. The context menu allows you to Edit, Copy, or Delete a label style. The Edit and Copy options open the Label Style Editor dialog box which allows you to define a new label style.
