GOTOSTART command
Opens the Start page.
Opens or activates the Start page.
In the Start page you can:
- Create new drawings based on a specified template or open recent drawings through the Start tab.Note: The number of available recent files is controlled by the value of the RECENTFILES system variable.
- Access BricsCAD tutorials and sample drawings through the Learn tab.Note: Internet access is required.
- Access the Third Party Application catalog on the Bricsys website through the Apps tab.Note: Internet access is required.
- Have an overview of your most used commands and achievements through the Insights tab.Note: You need to join the BricsCAD Analytics Program to get insights.
