-HATCHEDIT command
Edits the boundaries of hatch entities at the Command line.
Edits the boundaries of hatch and gradient entities at the Command line.
Method
There are two methods to use -HATCHEDIT command:
- Select a hatch entity.
- Select a gradient entity.
Options within the command
- Disassociate
- Removes the associative property of the selected hatch or gradient entity.
- ADd boundaries
- The area of a hatch is modified by adding boundaries.
- Specify internal point
- The boundary is determined from an existing enclosed area around the specified point. The selected hatch is then associated with that boundary.
- Select entities
- The boundary is determined from the selected entities that form an enclosed area. The selected hatch is then associated with that boundary.
- Remove boundary
- The area of a hatch is modified by removing boundaries.
- ASsociate
- Associate the selected hatch or gradient entity to a different boundary set.
