HIDEOBJECTS command
Hides selected entities.
Icon:
Hides selected entities, like using the Freeze option of the LAYER command, but for individual entities. Hidden entities optionally stay hidden between drawing sessions.
Note: To return hidden objects to view, use the UNISOLATEOBJECTS command.
Note:
- The OBJECTISOLATIONMODE system variable controls whether the hidden state is saved or not.
- The HIDEOBJECTS command is enabled under BEDIT sessions.
