INTERFERE command
Shows volumes and areas of interference between two sets of ACIS entities.
Icon:
Alias: INF
Opens the Interference Manager panel if it was previously closed. See also the Interference Manager panel article.
Options within the command
- select Entities
- Defines the selection set.
- between Two sets
- Searches for interference between two distinct sets of entities.
- inside One set
- Searches for interference inside a set of entities.
- SETtings
Calculates the clash volume.
- Run Scan
- Runs the scanning.
