-LANDXMLEXPORT command
Exports Civil objects to a LandXML file via Command line.
Method
Select the Civil objects to export.
Opens the Save LandXML file dialog box to define the location and name of the output LandXML file.
Note: Exports BricsCAD Civil objects, such as Civil points, TIN surfaces and volume surfaces, gradings, alignments, strings.
