LANDXMLIMPORT command
Creates TIN surfaces or alignments from a LandXML file.
Icon:
Opens the Open LandXML file dialog box to select an XML file to import.
The following BricsCAD Civil entities can be imported from the specified LandXML file: Civil Points, TIN Surfaces, Horizontal Alignments (both Alignments by PI and Alignments by Elements are supported), 3D Alignments, and Strings.
Note: This command is not currently available on Linux.
Options within the command
- Draw Breaklines as Polylines
- Specifies if breaklines are imported as 3D polylines.
- Scale
- Scales the XML file units.
- Import without scaling
- Imports the XML file without scaling.
- Cancel
- Cancels the command.
Note:
- Draw Breaklines as Polylines option is available when importing TIN surfaces with breaklines.
- Scale, Import without scaling and Cancel options appear if the units in the drawing differ than those in the XML file.
