LAYOUT command
Creates, copies, renames, and deletes layouts.
            Icon:
Method
You can create an unlimited number of layouts in a single drawing. Each layout represents a sheet of paper.
Options within the command
- Lists the names of layouts already defined in the drawing.
- Set
- Switches to the specified layout.
- New
- Creates new layouts.
- Copy
- Creates a new layout by making a copy of an existing layout.
- Delete
- Erases layouts from the drawing.
- Rename
- Renames layouts.
- SAve
- Saves the mentioned layout as DWG or DXF files format.
- Template
- Imports layouts from DWG, DWF, or DXF drawing files.Specify the file name and the layout names.
- neXt
- Displays the next layout.
- Previous
- Displays the previous layout.
