LOGFILEON command
Turns on log file recording.
BricsCAD records all command text to the LOG file located in the folder specified by the LogFilePath system variable. The default name of the file is "drawingname_year-month-date_hour-minutes-seconds.log", such as drawing1_2029-08-31_08-32-46.log. Setting the LOGFILEMODE system variable to 1 has the same effect as the LOGFILEON command. You can open the resulting log file in Notepad or another text editor.
Note: Log files record all prompts from the program and all your keyboard input. It does not record mouse actions or other non-keyboard activities.
