-MOVEBLOCKSTOELEVATION command
Updates the Z value of a block's insertion point to match the value specified in the block attribute or in the corresponding GIS data via Command line.
Method
Select the blocks for which you want to update the elevations (Z coordinate).
You are prompted to edit the mapping for block elevations. You can further filter the selected blocks by name, or choose the map all option to proceed.
After selection, if the blocks have associated attributes or GIS fields you are prompted to specify the property mapping for them as follows:
- Specify property mapping for tag
The Command line lists all attribute tags assigned to the selected blocks, one by one, with the Elevation and none options available.
- Specify property mapping for feature
The Command line lists all attributes in the format GIS Layer: Field name assigned to the selected blocks, one by one, with the Elevation and none options available.
Options within the command
- only blocks with Name
- Allows you to filter the selection by typing a block name.Note: Only one block name can be entered.
- ? to list block names
- Lists the selected blocks names.
- map all
- Allows you to edit the mapping for all selected blocks.Note: The elevation update does not apply to selected blocks that do not correspond to the chosen block attribute tag or GIS field.
- Elevation
- Sets the Z coordinate of the selected blocks to the numeric value defined in the block attribute or in the GIS field currently displayed in the Command line.Note: Only the block geometry is moved. To synchronize block attributes, use the ATTSYNC command.
- none
- Sets no value from the attribute tag or GIS field currently displayed in the Command line to the Z coordinate of the selected blocks.
