MATBROWSEROPEN command
Opens the Render materials panel.
Alias: MATB
Opens the Render materials panel to display it in the current workspace. The Render materials panel appears at the same size and location that it did before it was closed or collapsed. Like any other dockable panel, the Render materials panel can be either floating, docked or stacked.
The Render materials panel offers access to materials used for renderings.
Material definitions are saved in the drawing. Each drawing contains the Global material. It is not possible to delete or rename the Global material. However you can edit its properties.
- Material library
- Home
- Search
- Menu
Material library
The material library is organized by categories. You can select a material from a category and then apply it to an entity using the brush that appears on the screen. You can scroll through the materials using the mouse wheel or the scroll bar.
Home
Returns the material library to the home screen.
Search
Searches the library for words you enter in the search box.
