MEASURE command
Places points or blocks along entities at equally-spaced specified distance.
                Icon:
Method
Specify the entity you want to measure and enter a block distance value or insert a block. On the entity the points are places at equally-spaced specified distance.
                Note: Points are usually invisible, so use the PDMODE system variable to make them larger.
            Options within the command
- Insert block
- Inserts a block instead of a point.
- Align blocks with entity?
- Rotates the blocks to match the entity alignment.
