POINT command
Creates a point.
                Icon:
Alias: PO
Creates one or multiple points, controlling their size and style.
Method
Create a single point, represented by a dot, by specifying the location of point.
Options within the command
- Location of point
- Specifies the location of the point.
- point Settings...
- Opens the Settings dialog box to specify the display mode and size for points.
- Multiple points
- Draws multiple points until you press Enter key to end the command.
