-OPENSHEETSET command
Opens a sheet set file.
Opens a DST sheet set file, and then displays the Sheet Sets panel which lists all drawings and sheets associated with the set; meant for use by macros. An example of path and file name of a DST sheetset file is F:\work\Documentation\Documentation\project.dst.
