-PAN command
Moves the entire drawing.
Alias: -P
Moves the entire drawing within the current viewport.
Note: The PERSPECTIVE system variable must be set to 0.
Method
There are two methods to use -PAN command:
  • Pick a base point and a displacement point.
  • Choose one of the predefined options.
  1. Pan base point.
  2. Pan cursor which specifies the pan displacement point.
  3. Pan displacement.
Options within the command
Pan base point
Specifies the pan distance’s starting point.
Pan displacement point
Specifies the pan distance’s ending point.
Note: The drawing is panned by 5% or 100% of the width of the current viewport.
Left
Pans the drawing 5% to the right.
Right
Pans the drawing 5% to the left.
Up
Pans the drawing 5% downwards.
Down
Pans the drawing 5% upwards.
PaGe Left
Pans the drawing 100% to the right.
Note: You can also press Shift + Left cursor key.
PaGe Right
Pans the drawing 100% to the left.
Note: You can also press Shift + Right cursor key.
PaGe Up
Pans the drawing 100% upwards.
Note: You can also press Shift + Up cursor key.
PaGe Down
Pans the drawing 100% downwards.
Note: You can also press Shift + Down cursor key.
