PERSPECTIVE system variable
Perspective
Turns on perspective view for the current viewport.
Type:
Boolean
Saved in:
Drawing
Default value:
Off
Possible values:
Off (0): Perspective view off
On (1): Perspective view on
Related commands
  • ALIGNSPACE command
  • BACKGROUND command
  • DVIEW command
  • FLATTEN command
  • LOOKFROM command
  • MATCHPERSPECTIVE command
  • PAN command
  • -PAN command
Related variables
  • UCSORTHO system variable
Related information
  • Using the LookFrom control
