-PARAMETERS command
Manages dimensional-constraint parameters.
Creates, edits, renames, and deletes parametric equations made of dimensional constraints and user-defined variables; works at the Command line.
Options
- Lists all dimensional constraints and user variables in the current drawing, showing the name, expression and current value of each dimensional constraint or user variable.
- New
- Creates a user variable.
- Edit
- Edits the expression for the dimensional constraint or user variable.
- Rename
- Renames a dimensional constraint or user variable.
- Delete
- Deletes a dimensional constraint or user variable.
- Properties
- Sets the lower and the upper bounds for the parameter.
- Lower bound
- Defines the lower value for the parameter.
- Upper bound
- Defines the upper value for the parameter.Note: The upper and lower bounds are taken into account in dynamic operations, like DMMOVE and ROTATE3D.
