-PSETUPIN command
Imports user defined page setups via Command line.
Imports user defined page setups from another drawing through the Command line.
Note: Page setups define printing settings, see the PAGESETUP command and New Page Setup dialog box articles.
Method
Run the command to open the Select Page Setup From File dialog box and choose a drawing from which to import user defined page setup(s), then specify the name of the page setup(s) to import.
