-PUBLISH command
Prints the content of a DSD file.
Prints the content of a Drawing Set Description (*.dsd) file at the Command line.
Note: Create the DSD file with the PUBLISH command. The DSD file specifies the file name, layouts, page setups, plotter and printer names, orientation, plot scale, number of copies, optional plot stamp, and the order in which to plot the files.
Note: This command adds a watermark to publish output obtained using an Academic license.
Method
Select a DSD file in the Select Sheet List dialog box.
Note: If the BACKGROUNDPLOT system variable is 2 or 3, the sheets are printed in the background.
