BACKGROUNDPLOT system variable
Background plotting
Controls if background plotting is enabled for plot and/or publish actions.
Type:
Short
Saved in:
Registry
Range:
0 to 3
Default value:
2
Possible values:
0: None
1: When plotting (Not yet supported)
2: When publishing
Related commands
  • PLOT command
  • -PLOT command
  • PUBLISH command
  • -PUBLISH command
Related variables
  • PUBLISHALLSHEETS system variable
  • PUBLISHCOLLATE system variable
Related information
  • Publish dialog box
