PAGESETUP command
Opens the Drawing Explorer dialog box with Page Setups selected.
Icon:
Opens theāÆDrawing Explorer dialog boxāÆwithāÆPage SetupsāÆcategory selected to view and modifyāÆpage setups in the current drawing.
Context Menu Options
- New
Loads additional page setup definitions into the drawing. Displays the New Page Setup dialog box.
- Delete
Deletes page setup definitions from the drawing. The following page setup definitions cannot be deleted:
- The Model tab
- The last layout
- Edit Page Setup
Edit the selected page setup. Displays the Page Setup dialog box. Here you can edit the properties of the selected page setup.
- Rename
Renames the selected page setup.
Note: The following page setups cannot be renamed:- The Model tab
- The Layout tabs
- Select All
- Selects all page setup definitions.
- Invert selection
- Deselects the current selection and vice versa.
