PAN command
Moves the entire drawing.
                Icon:
Alias: P
Moves the entire drawing in real- time within the current viewport.
Note: Real-time means that the drawing moves as the mouse moves.
            Note: The PERSPECTIVE system variable must be set to 0.
            After running the command, the cursor changes into a hand icon. Hold down the left mouse key and then move the mouse to pan the drawing or right-click to open the Pan context menu.
Note: Pan the drawing also with the scroll bars. Turn them on with the SCROLLBAR command.
