PARAMETRIZE command
Applies constraints automatically.
Automatically adds geometric constraints and parametric equations to 3D solid geometry. The resulting parameters and geometric constraints can be viewed and edited in the Mechanical Browser panel (MECHANICALBROWSEROPEN command).
When the ROLLOVERPARAMS system variable is ON, the parameters can also be edited from Model Space via Rollover Tips when hovering over the blocks.
Note: To activate the Rollover Tips (RT) option, set the ROLLOVERTIPS system variable to ON or activate the RT button in the Status bar.
