PARAMETRIZE2D command
Automatically applies 2D geometric and dimensional constraints to selected 2D geometry.
Select the 2D entities to automatically add dimensional and geometric constraints.
The parameters and constraints can be edited in the Properties panel, the Parameters Manager panel, or the Mechanical Browser panel.
When the ROLLOVERPARAMS system variable is ON, the parameters can also be edited from Model Space via Rollover Tips when hovering over the blocks.
Note: To activate the Rollover Tips (RT) option, set the ROLLOVERTIPS system variable to ON or activate the RT button in the Status bar.
