PBLOCKOPERATIONSDISPLAY command
Shows/hides parametric block operation definition lines.
Icon:
Method
The command manages the visibility of parametric block operation definition lines that are attached to the selected entities.
The approach for parametric block operation geometry is that of a non-database-resident geometry, with the geometry being created on an anonymous layer.
Note:
- When opening a new drawing, the local parametric block operation geometry is not visible by default.
- When a parametric operation is copied, the geometry of the new operation is set visible by default.
- When all entities that are affected by a parametric operation are copied, the parametric operation is also copied and set visible by default.
- When a BEDIT session is started, all local parametric block operations geometry is visible by default.
Options within the command
- Show
- Shows the parametric block operation geometries of the selected entities.
- Hide
- Hides the parametric block operation geometries of the selected entities.
