PBLOCKREFERENCEACTIONSVISUALIZATION system variable
Parametric block actions references visualization
Enables the visualization of the parametric operations' geometries when hovering over parametric block references in model space.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Visualization off On (1): Visualization on |
