PDFCLIP command
Clips a PDF underlay to a specified clipping boundary.
Icon:
Method
Select the PDF underlay and then enter the PDF clipping options.
Options within the command
- ON
- Turns On the clipping boundary that was turned Off by the OFF option.
The area outside the clipping boundary is hidden from the view.
- OFF
- Turns Off the clipping boundary so the selected PDF is fully visible again. The clipping boundary is saved, until it is deleted, and it can be turned On again with the ON option.
- Invert
- Inverts the clipping mode so that the PDF is clipped either outside or inside the specified boundary.Note: The Misc section of the Properties panel also allows you to turn the clipping On and Off, and to invert it.
- Delete
- Erases the clipping boundary from the selected PDF without prompting or warning you.
- New
- Allows you to add a clipping boundary to the selected PDF.
- Polygonal
- Creates non-rectangular clipping boundaries, with a minimum of three sides.
- Undo
- Undoes the last point.
- Rectangular
- Creates rectangular clipping boundaries.
