PEDITEXT command
Edits vertices and segments of a polyline.
Icons:
Edits vertices and segments of a polyline interactively, without first selecting the polyline.
Note: This command was meant for use with the Quad cursor. See
the related procedure Editing a polyline using the Quad on how to use this
command with the Quad.
Options
- Add vertex
- Adds a vertex to the selected segment.
- add vertex at the End
- Adds a new vertex at the end of the polyline.
- adjust Bulge
- Modifies the bulge factor of the selected segment.
- Remove segment
- Deletes the selected segment.
- Stretch segment
- Moves the selected segment.
- Stretch Vertex
- Moves the selected vertex.
