PLOTSTAMP command
Opens the Plot stamp dialog box.
Opens the Plot stamp dialog box to add information about drawings to the edge of the plotted drawing.
- Header
- Footer
- Font
- Size
Header
Appears at the top of the plot. A meta-phrase for the header can be chosen by clicking the drop-down list. You can also specify the X and Y offsets for the header.
Footer
Appears at the bottom of the plot. A meta-phrase for the footer can be chosen by clicking the drop-down list. You can also specify the X and Y offsets for the footer.
Font
Specifies the font used for the plotstamp.
Size
Specifies the height of the text.
- Inches: specifies the height of the text in inches.
- Millimeters: specifies the height of the text in millimeters.
