PLOTSTYLE command
PLOTSTYLE command
Sets the current plot style.
The command opens the Current Plot Style dialog box where you can set the current plot style.
Note: This command operates only when plot styles are enabled in drawings.
  • CONVERTCTB command
  • CONVERTPSTYLES command
  • Layers panel
  • Page Setup dialog box
  • PRINT command
  • PROPERTIES command
  • STYLESMANAGER command
